Help Obtaining Cbush Nodes and Coordinates- API
I was wondering if there is a way to output the nodes specifically connected to a Cbush. For example, Cbush 1 connected to Node ID 323 and Node ID 525 and their coordinates. I have code that loops through nodes and shows their coordinates and ID.
Code that loops through all nodes:
The HTML Clipboard
Sub Main
    Dim app As femap.model
    Set app = feFemap()
    Dim fNode As Object
    Dim fSet As Object
    Dim nodeID As Long
    Dim xcoordinate As String
    Dim ycoordinate As String
    Dim zcoordinate As String
    Dim nodeIDstr As String
    Dim xyz(3) As Double
    Dim vXYZ As Variant
    Set fNode=app.feNode
    Dim fnodeset As Object
    Set fnodeset=app.feSet
    Set fSet=app.feSet
    vXYZ = xyz(0)
    rc=fSet.Select(7,True,"Select Nodes")
    nodeID=fSet.First
While nodeID> 0
    rc=fNode.Get(nodeID)
    rc=app.feCoordOnNode(nodeID, vXYZ)
ID=nodeID nodeID=fSet.Next x=vXYZ(0) y=vXYZ(1) z=vXYZ(2) nodeIDstr=ID xcoordinate=x ycoordinate=y zcoordinate=z app.feAppMessage(0,"The coordinate of Node "+nodeIDstr+" is ("+xcoordinate+", "+ycoordinate+", "+zcoordinate+").") Wend End Sub
 Sample output when code is run:
The coordinate of Node 667 is (2, 6, 0).
The coordinate of Node 668 is (14, 4, 0).
The coordinate of Node 669 is (12, 4, 0).
The coordinate of Node 670 is (10, 4, 0)
Thank you!
Re: Help Obtaining Cbush Nodes and Coordinates- API
You are pretty close. To finish this, you can benefit from the ".AddRule" and ".AddSetRule" methods on Set Objects. This will first add all elements of type "CBUSH" (aka a Spring/Damper Femap element type) then grab the nodes from that set in a new set.
In addition, you are using "... As Object" when you create your objects. This is fine, except you lose the IntelliSense that can help steer some programming. Below I have the completed API plus some commented lines that show how you can create Femap-style objects instead.
Sub Main
Set app = feFemap()
Dim fNode As Object
'Dim fNode As Node
Dim fSet As Object
'Dim fSet As femap.Set
Dim eSet As Object
'Dim eSet as femap.Set
Dim nodeID As Long
Dim vXYZ As Variant
Set fSet=app.feSet
Set eSet=app.feSet
Dim e As Elem
Set e = app.feElem
'Use .type method on element object to make it CBUSH
' *TIP* with your curser somewhere on ".type", hit F1 to jump to the defintion in the FEMAP Help
e.type = FET_L_SPRING
vXYZ = xyz(0)
'rc=fSet.Select(7,True,"Select Nodes")
'Use versatile ".AddRule" method on Set object to add all nodes on CBUSH type elements
eSet.AddRule(e.type,FGD_ELEM_BYTYPE)
'Use versatile ".AddSetRule" method to add all nodes on Elems from eSet
fSet.AddSetRule(eSet.ID,FGD_NODE_ONELEM)
nodeID=fSet.First
While nodeID> 0
ID=nodeID
nodeID=fSet.Next
x=vXYZ(0)
y=vXYZ(1)
z=vXYZ(2)
nodeIDstr=ID
xcoordinate=x
ycoordinate=y
zcoordinate=z
Wend
End Sub
Consider using the data table as well.  Enable the data table, then the selector, setting it to "nodes".  You can use the standard dialog selection to select by element and pick your cbush elements.  The info you want will be in the data table.
Eric Gustafson
Author, Learning Femap
Hey guys, thank you for the help. Your posts gave me multiple ideas that I ended up implementing. I went ahead and also integrated more code sourced from the api pdf and older projects.
The code now finds the coordinates, cbush Id, property id, elem type, nodes A and B, and lists them accordingly. I will mark this as a solution for anyone who might need the api.
A sample output:
The coordinate of Node 229 is (6, 16, 0).
The coordinate of Node 111 is (2, 16, 0).
Load ID 42, Propety ID 7, Elem Type 6, Nodes 229, Nodes 111
code below: The HTML Clipboard
Sub Main
    Dim App As femap.model
    Set App = feFemap()
Const MAX_NODES_PER_ELEM = 20
Dim fNode As Object
Dim fSet As Object
Dim nodeID As Long
Dim vXYZ As Variant
Set fNode=App.feNode
Set fnodeset=App.feSet
Set fSet=App.feSet
Dim elemset As femap.Set
Set elemset=App.feSet
Dim eset As femap.Set
Set eset = App.feSet
Dim nset As femap.Set
Set nset = App.feSet
Dim fstr As String
Dim elemmode As Long
Dim e As femap.Elem
Set e = App.feElem
Dim p As femap.Prop
Set p = App.feProp
Dim eset2 As femap.Set
Set eset2 = App.feSet
Dim El As Object
Set El = App.feElem
Dim elSet As Object
Set elSet = App.feSet
Dim numElem As Long
Dim entID As Variant
Dim propID As Variant
Dim elemType As Variant
Dim topology As Variant
Dim Lyr As Variant
Dim color As Variant
Dim formulation As Variant
Dim orient As Variant
Dim offset As Variant
Dim release As Variant
Dim orientSET As Variant
Dim orientID As Variant
Dim nodes As Variant
Dim connectTYPE As Variant
Dim connectSEG As Variant
Dim Msg As String
Dim findElemType As Integer
findElemType = 6 'Linear Plate
rc = elSet.AddRule(findElemType, FGD_ELEM_BYTYPE)
rc = El.GetAllArray(elSet.ID, numElem, entID, propID, _
elemType, topology, Lyr, color, formulation,orient,offset, _
release, orientSET, orientID, nodes, connectTYPE, connectSEG )
vXYZ = xyz(0)
e.type = 6
eset.AddRule(e.type,FGD_ELEM_BYTYPE)
fSet.AddSetRule(eset.ID,FGD_NODE_ONELEM)
nodeID=fSet.First
App.feAppMessage(FCL_NORMAL, _
" Number of Cbush elements: " + Str$(numElem))
For i = 0 To numElem-1
' Load ID, property, type, and nodes into String for display
Msg = "Load ID" + Str$(entID(i)) + ","+ " Propety ID"+Str$(propID(i)) + ", "+ _
    "Elem Type" + Str$(elemType(i))
    For u = 0 To MAX_NODES_PER_ELEM-1
If nodes(i*MAX_NODES_PER_ELEM + u) <> 0 Then
    vc=fNode.Get(nodeID)
    vc=App.feCoordOnNode(nodeID, vXYZ)
    nodeID= nodes(i*MAX_NODES_PER_ELEM + u)
    ID = nodeID
    nodeID=fSet.Next
    x=vXYZ(0)
    y=vXYZ(1)
    z=vXYZ(2)
    nodeIDstr=ID
    xcoordinate=x
    ycoordinate=y
    zcoordinate=z
Msg = Msg + ", " +"Nodes" + Str$(nodes(i*MAX_NODES_PER_ELEM + u))
App.feAppMessage(0,"The coordinate of Node "+nodeIDstr+" is ("+xcoordinate+", "+ycoordinate+", "+zcoordinate+").")
End If
Next u
App.feAppMessage(FCM_NORMAL, Msg)
Next i
End Sub
A sample output:
Sub Main
    Set App = feFemap()
Dim fNode As Object
Dim fSet As Object
Dim nodeID As Long
Dim vXYZ As Variant
Set fSet=App.feSet
Dim fstr As String
Dim e As femap.Elem
Set e = App.feElem
Dim p As femap.Prop
Set p = App.feProp
Dim El As Object
Set El = App.feElem
Dim elSet As Object
Dim numElem As Long
Dim Lyr As Variant
Dim Msg As String
vXYZ = xyz(0)
e.type = 6
nodeID=fSet.First
    ID = nodeID
    nodeID=fSet.Next
    x=vXYZ(0)
    y=vXYZ(1)
    z=vXYZ(2)
    nodeIDstr=ID
    xcoordinate=x
    ycoordinate=y
    zcoordinate=z
End If
Next u
Next i
End Sub
