Highlighting Elements or Nodes by copying their ID number from excel,...
Builder
Builder
I have a bunch of Element and Node ID numbers listed in excel, I would like to know if I can bring them in Femap and locate/highlight them,... like copy/paste them in "Entity Selection Menu" in femap,...? Should it be done via Femap API?
Thank you!.
Aero1
Re: Highlighting Elements or Nodes by copying their ID number from excel,...
No API is needed.
Copy them from Excel then use Window-Show Entities ( Node/Elem). The list can be pasted into the Entity Selection dialog box by using the "Pick" button then "Paste".
Dan
Builder
Builder
Perfect!, thank you, I didn't know that I have that "Pick button/Paste" option,...!!!.
