How to Find Common Elements Between Two Groups in Femap
Hi
I would Like to know the common elements between Group-1 and Group-2 so that the common Elements can be moved o new Group-3.
Any Help please
srini
Re: How to Find Common Elements Between Two Groups in Femap
Go to Group / Operations / Booleans and do the following:
Seifeddine Naffoussi
Go to Group > Operations > Booleans > "In All" and select groups 1 and 2.
This will create a new group containing all entities in both groups.
Hi
Thank you so much for the Reply. But this will work only  Common elements are there betweent the Groups.
Say Group1 and Group2 has common elements
and Group2 and Group3 has Common Elements.
When I select Group1 Group2 and Group3 . The resultant Group has Empty Elements.
If you will work with three groups as you mentionend so you can create a fourth group using "Only in One" then activate the show mulitiple groups / show your three groups and hide the fourth one.
Next you will be able to see only the common elements for the three groups.
Give it a try and see if does what you want.
PS: Femap does not export groups in a .dat file. Make a neutral.
