How to activate TMG menu for CFD analysis
I have a TMG flow and Thermal licence but I am unable to get its toolbar available under Tools>Toolbars.
I already unistalled and reinstalled the Femap Flow and Thermal option, reinstalled the entire femap, without solution.
If I open the FEMAP and then run the femap/TMG/FEMAP/COM/satmg the menu appears and everything seems to be working BUT anytime I open any dropdown menu inside any TMG tool it freezes and I have to force the process shutdown using task manager.
Version is FEMAP 11.1.1 on windows 10- 64 bits on a lenovo P40 yoga
Any idea on why is this happening and solution?
thanks
Re: How to activate TMG menu for CFD analysis
You may have deleted the toolbar accidently.  Try resetting the UI in the Femap Preference dialog box under the UI tab.  That should make the TMG toolbar available again.
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
During installation, the mechanism that creates the TMG menu in FEMAP is pretty old school stuff, please contact me directly and we'll work through this outside the forum.
sherman dot mark at siemens dot com
Mark.
