How to call an API from within another API?
I would like to run many *.BAS files consecutively from a master BAS file. Does anyone know the right method/procedure for this? The feFileProgramRun below does not seem to work as I hoped.
rc=App.feFileProgramRun(False,True,True,"D:\XX\renumber.BAS")
Kris
Re: How to call an API from within another API?
Same here, and I've never taken the time to fully understand the ins and outs of this issue, events, whether a .PRG is required...etc...
However my workaround is to use the VB statement MacroRun:
MacroRun "D:\XX\ren​umber.BAS" should work fine.
This is a pretty cool command because you can also pass arguments to it, which opens many possibilities. We have a bunch of "API building blocks" that we can put together to create bigger, more complexe tools.
Checkout the WinWrap help for complete details.
For example
C:\tmp\test.BAS =
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    App.feAppMessage(FCM_ERROR,CStr(Command$))
End Sub
and then this "API which calls another API":
Sub Main
    MacroRun "C:\tmp\test.BAS", "wOOt!"
End Sub
AP
@astrium_tls
Very cool! Didn't know it is possible and specially with arguments.
Yarko
Thanks a lot!
This works really well! The script also waits for the macro to finish which is not the case with feFileProgramRun.
-Kris
