Do you mean
Reply
Solved! Go to solution
How to find the maximum contour value from different load cases,...
Is it possible to find the maximum contour value from different load cases? For instance, plate maximum Fxy force value from two different load cases,...
Aero1
Solution
Solution
Accepted by topic author Aero1
‎02-09-2017 12:26 PM
Re: How to find the maximum contour value from different load cases,...
Yes, you want an Envelope. Select all relevent result cases from the tree, right-click and select Envelope (max or max absolute if you have neg. values of interest).
Perfect!, thank you!.
