How to get nodal results available when attach or import abaqus results
An analysis model from Abaqus was saved as ODB file. Model has Hex and Tet meshes.
The model was then opened in Femap and the results are attached.
Now we can't get nodal stress results. Ofcourse we toggles Elemental/ Nodal results display, but the nodal results are not available. We don't know of this can be influenced by the export/ save options in Abaqus, or import functionality in Femap.
Has someone experience with this? Any tips to get the full results available in Femap?
Re: How to get nodal results available when attach or import abaqus results
Any chance we can get a copy of the model and odb?  Or perhaps a test case that raises the same issue?
