How to include a surface in a group after creating it
Hi! I've just started to work with FEMAP and I'd like to know how to include a plate in a group. I've already created the plate, but I forgot to include it in a group at the beginning. The plate is already done, I just wanna to include in a group that does not exist yet.
Thanks!
Re: How to include a surface in a group after creating it
Group -> Create/Manage (to create a group).
Assuming you mean a plate element, then Group -> Element -> ID (select the plate element), or Group -> Element -> Type (or shape, or property) if you want subsequent new plates to also belong to the same group.
If by "plate", you mean a geometry surface, then it would be Group -> Surface -> ID then select the Surface.
It worked! Thanks!
