How to increase node size
How do I increase the size of a set of particular nodes. For instance, I have a group of nodes which I want to appear larger than the rest of the nodes in my model.
Stressman
Re: How to increase node size
Dear Stressman,
Simply use "Modify > Color > Node" and select the nodes you want to change the color. Select a color and make sure to choose the size you most like under LINE STYLE ...
Best regards,
Blas.
WEB: http://www.iberisa.com
Wonderful, thank you Blas, I didnt know the Line Style could also applied to points/nodes
