cancel
How to make more memory
How to make more memory when the FEMAP  message show that  "You are almost out of memory for this process (59 MBytes).Save immediately. Reconfigure to use less memory or make more memory available"?
Re: How to make more memory
Dear SPC,
If the message appears it means that you are extremely low in RAM memory: please note this is FEA, not CAD, then RAM memory here is critical.
How to save RAM memory?. Simply, close all programs in execution before running FEMAP, not other trick exist, you can remove & uninstall any other software that could be resident in RAM memory (antivirus, etc..).
Best regards,
Blas.
WEB: http://www.iberisa.com
