Do you mean
Reply
Solved! Go to solution
How to save or(and) show the failed elements on the center of the graphics window ?
Solution
Solution
Accepted by topic author SPC
2 weeks ago
Re: How to save or(and) show the failed elements on the center of the graphics window ?
[ Edited ]
While in the meshing toolbox, click on 'Toggle Entity Locator'. Here you have the option to search for elements by quality. Once you selected your failed elements, you can save them to a group using the 'Create Group' command located in the pull down menu near the toggle entity locator.
