How to select an item from a listbox using variables through macros?
Hello, everybody!
The FEMAP's Users Guide shows that to select an item in a listbox or combobox is necessary to use <~...> where the "..." is the index of the item. For example, to choose the Output Set 1 is necessary to write:
$ Manage Output Sets
{~1235}
$ ----- Output Set Manager
<@18000><~0><OK>
I need that this index be a variable. I tried:
#DEF(j,0)
{~1235}
<@18000><~!j><OK>
But didn't work. I also tried to use <~j>, !j and j but nothing worked. Does somebody knows how to do this?
Fabiano
