How to select elements using nodes through API
Hello, everybody!
I needed to add to a set, elements that use nodes that were contained in another set (do the same that the command "Group/Elements/Using Nodes..."). How can I do this through API?
Best regards,
Fabiano.
Re: How to select elements using nodes through API
 If nSet is your nodes, elSet your elements:
elSet.AddSetRule(nSet.ID,FGD_ELEM_BYNODE)
All info regarding the concept of rules can be found in the Set chapter of the API help.
Checkout 4.6.2.5 AddSetRule, 4.6.2.6 AddRule and 4.6.2.7 Group Sleection Rules
AP
