Huge model file zise after deleting results
I have ran a simulation that creates a large file after the run (73 GB .modfem file) in sol701.
My problem is that when I delete the results and then try to save the file without the results, the new saved .modfem file is still 73 GB. How can I reduce the file size without the results (it takes more than 15 minutes to save each time).
Thanks.
Re: Huge model file zise after deleting results
Have you tried "File > Rebuild"?
Check out Help > Commands > 2.6.1 Rebuild for detailed explanations
Hello!,
"File > Rebuild", next SAVE ... and you are done!.
Best regards,
Blas.
WEB: http://www.iberisa.com
Thanks for the quick reply, I will try it.
Thanks for the quick reply, shrinked from 73 GB to 150 MB...
