Identify nodal results in FEMAP
Hallo,
How do you pick result in custom important nodes?
Is in FEMAP similar funcktion like in NX: IDENTIFY RESULT?
And even better highlighted by link (annotations).
Or how do you make it ?
Thank for your idea.
TomasHavlicek
Re: Identify nodal results in FEMAP
Dear Tomas,
In the SELECTOR ENTITY toolbar choose NODE, then in the SELECTOR MODE activate SHOW TOOLTIPS, from now in advance each time you hover on a NODE in an active window with displacements or stress results you will get a balloon with a summary of the results.
TRICK: If you move the mouse fully inside over the text balloon and click the RMB you will see the option CONVERT TO TEXT, allowing you to have the balloon converted to text. Next use command MODIFY > EDIT > TEXT and made the modifications you like in both text content, color, position, etc..
Best regards,
Blas.
WEB: http://www.iberisa.com
Dear Blas,
thank you for quick reply.
For Translation results works well, but for stress results, there are no text with value.
See bellow. There are only coord.
Is possible cennect text window with node by leader?
Thank You
Tomas Havlicek
Dear Tomas,
If you plot elemental stress results, then choose ELEMENT in the SELECTOR ENTITY, not nodal stress results are plotted.
Edit the text and in the STYLE include POINTER, then you can point to any place of the screen. Also learn to play with text justification or text position: VIEW vs. MODEL.
Best reards,
Blas.
Hi Blas,
perfect,
nodal/element contour = my fault :-)
Now its OK.
Thank you
Good news for our potencial customer.
Now he will buy FEMAP.
It was his last requirement.
Best regards
Tomas Havlicek
