Is FEMAP API Thread Safe?
Can I make calls to the FEMAP API in a multithreaded application, or does it have to be called from the main thread?
Re: Is FEMAP API Thread Safe?
FEMAP API does not support multi-threading.
Thanks, I couldn't find a definitive answer in the docs.
