Issue with feBoundaryFromCurves API method
If I use feBoundaryFromCurves(setID) method and curves in the set are not connected, I get an error message and an entity selection dialog box to select curves:
This is unnecessary, this method has a return value, and I can write in my code a routine to solve, when return code is FE_FAIL (for example merge endpoints of curves).
Best regards,
Peter Kaderasz
