JT compatibility with Femap
I save a JT version 10. file using Femap 11.2 but I can not see the FEM model using J2Tgo 10.1.3. I see only labels and contour scale. Any suggestion or is it a known issue ? Thank you
Franco
Re: JT compatibility with Femap
I have not been able to duplicate this error using Femap v11.2 and the JT2Go v10.1.3 viewer as shown in the attached example.
Did you see any error messages when generating the JT file?
Also, what graphics card are you using and is the driver the latest version?
Best Regards,
Chip Fricke
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
