License borrowing in FEMAP
Hi All. I just want to ask whether FEMAP allows license borrowing, via FlexLM or some unknown app that I haven't discover yet
Re: License borrowing in FEMAP
Dear Edward,
Yes, FEMAP licensing support BORROW freature, but we have a specific borrowing utility which does NOT use the “Borrowing” tab of LMTools. You need to request to SIEMENS a special license file which has borrowing enabled and some additional instructions on how to use the FEMAP Borrowing utility.
I can tell you that the borrowing feature runs OK, we have FEMAP customers in Spain using this feature with success!!.
Best regards,
Blas.
WEB: http://www.iberisa.com
The License borrow option doesn't come pre-installed in FEMAP, and i do not see any option to install a "borrow utility" in the installation media, do you have a documentation from Siemens that specifies that borrowing can be made, since there is almost zero documentation from Siemens about license borrowing.
For the utility and the license (with borrow feature), is it a special request to Siemens, or it's just another add on ?
Thanks for the clarification Smiley Happy
Dear Edward,
To activate the BORROW feature in your FEMAP floating network license you need to contact with the FEMAP developpers (or SIEMENS GTAC), you will receive a special license with instructions to setup the borrowing feature, OK?.
Best regards,
Blas.
Thank you. This has been very helpful Smiley Happy
