List Elements in layer/group
Hi
I am a new user of FeMap. I am creating a fairly complex assembly model where I have seperated individual parts into layers and groups.
I was wondering is there a way to list the number of elements/ nodes for each layer/group.
As an adhoc method I am doing the following:
View only one layer at a time -> List -> Model -> Elements -> Select all Elements -> Highlight
This gives the the number of elements in the layer. I was wondering if there is a command for doing this in one step for the entire model.
Thanks in advance.
Saptarshi
Re: List Elements in layer/group
This API lists the number of elements for layers and groups.
-Kris
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim lay As femap.layer
    Set lay = App.feLayer
    Dim eleSet As femap.Set
    Set eleSet = App.feSet
    Dim gr As femap.Group
    Set gr =App.feGroup
    'List layers, number of elements
    While lay.Next
    	rc=eleSet.Clear 'empty set on each loop
	rc=eleSet.AddRule(lay.ID,FGD_CURVE_BYLAYER)
	App.feAppMessage(FCM_NORMAL,"Layer " +Str(lay.ID) + " elements: " +Str(eleSet.Count))
    Wend
 'List groups, number of elements
    While gr.Next
    	rc=gr.Get(gr.ID)
    	rc=gr.GetList(FGR_ELEM,eleSet.ID)
	App.feAppMessage(FCM_NORMAL,"Group " +Str(gr.ID) + " elements: " +Str(eleSet.Count))
    Wend
End Sub
Hi Kris,
I tried the code you provided. Unfortunately, the layers are listed but the elements are not listed. All layers report 0 elements.
eg:
Layer 1 elements: 0
Layer 2 elements: 0
Layer 3 elements: 0
Layer 4 elements: 0
Is there something else that I have to do before running the code. What I understood from the script, the eleset.count is not working correctly as it is returning a value of 0.
Saptarshi
Dear Saptarshi,
In the script provided by Kris one line should be changed:
On this:
 rc=eleSet.AddRule(lay.ID,FGD_ELEM_BYLAYER)
Because it requests curves in layers and you need elements.
Yarko
Exactly! Sorry for the typo!
-Kris
