Mesh solids - merge nodes = Off (API)
We are building a parametric model in Femap using API. We mesh few solids and create a contact between them. For meshing, we use command feMeshTetSolid2 and it merge for 2 neighbour solids.
When we use command Mesh - Geometry - Solids from interface, there is a command to turn off Merge Nodes:
It seems that in feMeshTetSolid2 function there is no such parameter. Where can we change this option via API?
Yarko
