Meshing Problem - CFD TMG
Builder
Builder
Hello everyone,
I am performing CFD Analysis on the porous material using FEMAP TMG flow analysis.
Due to porous geometry, I have performed the Boolean operation by subtracting it from the simple cube. Afterward I try to perform the meh, unfortunately, it aborted even though I use very fine mesh size and check the geometry thoroughly.
But when I performed the meshing before subtraction it works fine. Might be some curve generated which is difficult to mesh.
Does anybody guide me how can I solve this issue.
Many thanks in advance.
Warm Regards
Re: Meshing Problem - CFD TMG
I was able to mesh your geometry by first applying the command, Mesh > Geometry Preparation
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
Builder
Builder
Could you please tell me what are the meshing size did you choose during the geometry prepartion.
