Option to Reverse Freebody Vector Display?
Is there an option to reverse the display of the freebody vectors?
Meaning just as with my load vectors I can select the "reverse option" under View Options and this changes moves the head of the nodal load vectors to the node, instead of having the tail of the vectors at the node.
Re: Option to Reverse Freebody Vector Display?
From  Whats new in Femap 11.2
Nodal summation freebody contributions can now be reversed.
Imbalances, such as glue and contact forces, can be treated as a summable contribution by reversing the sign.
