Program File with API
Dear all,
Is it possible to use the Program file in Femap and calling macro's in this program file? Or the other way round? Using API code and calling a program file?
So *.BAS into *.Pro or *.Pro into *.Bas
Daan
Re: Program File with API
Hi Daan,
From within API you can call "feFileProgramRun" to run a prgram file.
Reg.,
Chris
Hi Chris,
What's the exact code then for this command?
I'm pretty new in the API codes..
Hi Daan,
If you're pretty new in API code, then the 'api.pdf' in your Femap installation folder will certainly be nice reading stuff.
Reg.,
Chris
