Property Color Transparency not working in FEMAP 11.3
After updating to FEMAP 11.3, I can't figure out a way to get the 'Color With --> Property Colors' option to dipslay any sort of Pattern/Transparency options that are selected through the Color Palette.
Has anyone run into this issue yet / anyone have a solution or work around?
DrewL
Re: Property Color Transparency not working in FEMAP 11.3
Transparent entities display as opaque when Performance Graphics is enabled.  If you turn it off, entity transparency is displayed.
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
