Purge Group of all entities
I am trying to create a script that purges a specified group of all non-mesh entities and only leaves elements and nodes, but I seem to be having problems with the `RangeDeleteAll()` method. Here is my code:
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim rc As Long
    Dim gr As femap.Group
    Set gr = App.feGroup
    Dim nodeSet As femap.Set
    Set nodeSet = App.feSet
    Dim elmSet As femap.Set
    Set elmSet = App.feSet
    ' Select group to purge
    rc = gr.SelectID("Select group to purge")
    If rc = FE_CANCEL Then
        Exit Sub
    End If
    'Retrieve nodes and elements
    Set nodeSet = gr.Range(FGD_NODE_ID)
    Set elmSet = gr.Range(FGD_ELEM_ID)
    'Purge all
    rc = gr.RangeDeleteAll(-1)
    'Add nodes and elements
    rc = gr.SetAdd(FT_NODE, nodeSet.ID)
    rc = gr.SetAdd(FT_ELEM, elmSet.ID)
End Sub
The RangeDeleteAll() method seems to return an FE_OK code, but doesn't actually do anything. Can someone tell me what's going on?
Re: Purge Group of all entities
You need to Get and Put the group.  To do this, you need the group ID.   So in this case, instead of the gr.SelectID method you use, use App.feSet.SelectID method.
    Dim grID As Long
    rc = App.feSet.SelectID ( FT_GROUP, "Select Group to Purge", grID )
        Exit Sub
    End If
You also need to populate the sets differently:
The HTML Clipboard
    nodeSet.AddGroup ( FT_NODE, grID )
    elmSet.AddGroup ( FT_ELEM, grID )
The final API script should be something like this:
The HTML Clipboard
Sub Main
    Set App = feFemap()
    Dim rc As Long
    Dim grID As Long
        Exit Sub
    End If
    gr.Get ( grID )
    'Purge all
    gr.Put ( grID )
    App.feViewRegenerate ( 0 )
End Sub
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
That's perfect! Thanks, Chip!
