Re-map Pload4?
I have a model(all orphan meshes) with PLOAD4.
Is there any way to remap existing PLOAD4 into new meshes?
Re: Re-map Pload4?
Hello!,
A way could be to try to create geometry based in the existing mesh using command GEOMETRY > SURFACE > FROM MESH, this way (if you are success) you can play with both mesh density, loads & BCs, now based in geometry. This is a way to deal with legacy FEM models.
Best regards,
Blas.
WEB: http://www.iberisa.com
