Removing "dead elements" in post processing
Hi all,
When I allow rupture of elements (in sol 601/701) the "dead" elements become white (or whatever is the element base color), the thing is these "dead" elements continue to stretch and bind as the solution goes on, and there are cases where they simply block a lot of the other (not "dead") elements in the post processing and while viewing the results (and basically it will look much better if they could just be removed at post processing). Is it possible to remove them from the display?
Thanks.
