SOL701 STAMPING
Hi!
I'm new in SOL 701.
Now I am trying to simulate simple stamping process. You can see it on the picture below. I think the problem in material options, but can't understand where it hide.
 Solver gave me those output data
Here are the material settings
Tell me what I'm doing wrong.
best regards,
Yuliia
Re: SOL701 STAMPING
SOL701 is for very short duration dynamic events.  You should use either SOL601 Static or Transient.
Please refer to https://community.plm.automation.siemens.com/t5/3D-Simulation-Knowledge-Base/Sheet-Metal-Forming-wit...
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
Re: SOL701 STAMPING
Did you apply the load as a time-based load?
Best Regards,
Chip Fricke
Re: SOL701 STAMPING
Hello!
Unless your stamping velocities are very high, these stamping problems can usually be modelled as a static nonlinear problem. In your case, can you try SOL 601,106 instead of SOL701?
When defining your step, make sure you use enough increments per step to ensure convergence in the Newton-Raphson solver. (Solver options)
Cheers,
Jacques.
