Same nodes positions on both sides of the sector
I am trying to mesh a sector model (45 degrees for cyclic symmetry analysis) with exactly same node positions on both sides. I unsuccessfully used "Approach on Surface" command with different options.
How can I make it?
Thanks in advance,
Arcady
Re: Same nodes positions on both sides of the sector
Dear Arcady,
Use "Mesh > Sweep > Element", this command is really powerful and you can mesh with HEX elements instead TET.
Also take a look to this post: https://iberisa.wordpress.com/2011/10/16/mallado-con-elementos-hexaedricos-hex-meshing-iii/
Best regards,
Blas.
WEB: http://www.iberisa.com
Dear Blas,
Thanks for the detailed response. I try to use Hexa mesh all the time. But there are more complex cases where tetra meshing would be preferable and hexa-sweeping is expensive terms of time.
Best regards,
Arcady.
Dear Arcady,
You always can mesh previously ALL surfaces of the solid with PLOT PLANAR 2-D "SEED MESH" and use NEXT regular command "Mesh > Geometry > Solids" as ever, this gives you freedom to mesh any solid with TET elements after meshing locally any surface (face) of the solid with a 2-D quality mesh using any option of the "MESH > MESH CONTROL > APPROACH ON SURFACE" command.
The TET mesher will "honor" all the 2-D Seed mesh based in PLOT PLANAR elements.
Best regards,
Blas.
Dear Blas,
Thank you very much. I successfully used your tip.
Best regards,
Arcady
