Setting import geometry
Hello all. I am creating a geometric pattern in the program AutoCad, for import into Femap use format sat. In older versions of Femap 10.3.1 when importing geometry automatically combining geometric elements. Where and how to set up the tolerance on the value of this association? In the attached file, the geometric model,how to download in femap 11 without combining elements of geometry?
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Re: Setting import geometry
Go to File / Preferences / Geometry Model / Geometry Preferences and check Optimize geometry on Import. I've done the test and it properly import your geomerty. This option was added in the V11.1.XX releases.
Seif
Seifeddine Naffoussi
After canceling the "Optimize Geometry on Import" I have changed nothing. You did download the geometry v 11.1 as well as in my example in v 10.3?
You have to check it (activate) not cancel it. I've import it from Geometry / import and using the "Optimize Geometry on Import" to my Femap version 11.1.1
I is not working Man Sad
(view in My Videos)
I don't understand what is the problem by importing the geometry.
You would have each surface independently like in V10.3?
When you will mesh your geomtery you will need to merge those bracket surfaces and intersect them, no? How will you mesh this part?
The problem is that v 11.1.1 automatically combining surfaces and geometric distortion model. Import_Sat_03.PNG
If the geometry you want is the one you imported it in V10.3 then you can export a neutral file with only geometry and then open it with V11.1.1. You can also export a step file from Femap 10.3 and then import it in V11.1.1.
Then use Geometry / Midsurface / Intersect to cleanup the surfaces.
Does the original geometry come out of Inventor?  Or, regular AutoCAD?
Mark.
Geometry was created in Autodesk AutoCAD 2014 SP1
