Show Direction on Elements
Hi all,
Anyone noticed also, that Show Direction on Shell Elements did not work?
I try to show the plate element directions, by selecting :
> View Options (F6)
> Labels, Entities and Color
> Element - Directions
>  1..Normal Vectors
>  Activate 'Show Direction'
> Hit Apply or OK
but no arrows appear. Changing Enitity Colors or View Colors did not help.
Any other options that could influence the appearance ot the directions?
(Femap V11.1.0)
Chris
Re: Show Direction on Elements
Might be the "Performance Graphics" options ... Uncheck this option and try again.
This problem seems fixed in the last release of Femap (11.1.1).
And indeed, it is the "Performance Graphics' Option.
Currenlty using Femap V11.1.0 indeed, so should update to the latest release also.
Thanks !!
Chris
