Do you mean
Reply
Solved! Go to solution
Simple Bolt Check (AISC ASD 9th edition) API for FEMAP , Metric bolts
[ Edited ]
The attached FEMAP API program performs a simple bolt check (for bearing type) connections, according to AISC ASD 9th edition. Metric bolts are available from the drop down list.
It is intended for quick sizing of bolts (and it is best used with the hole-to-hole fastener macro available from the "custom tools" --> "meshing".
Output is printed to the message window, and looks like this (after copied to a text editor):
 The code is as follows:
'This macro is created to quickly check bolts according to AISC 9th edition
'(tension and shear check is considered only)
'No Responsibility is Taken For Results Obtained From this API
'Written for FEMAP 11.2
' Rev. 0 , Date: 21-02-2017, Created by P. Barabas (barabas.pete [ at ] gmail.com)
Sub Main
	'Attach the active FEMAP model to the macro
    	Dim App As femap.model
	Set App = GetObject(,"femap.model")
        RESTART:
Call Bolt
rc = App.feAppMessageBox(2,"Would you like to check other bolts?")
If rc = -1 Then
	GoTo RESTART
End If
End Sub
Sub Bolt
	'create an element set Object
	Dim Elem_set As Object
	Set Elem_set = App.feSet
	'create a load set object
	Dim load_set As Object
	Set load_set = App.feSet
	'create  element object
	Dim feElem As Object
	Set feElem = App.feElem
	'create output vector objects
	Dim ouVec1 As Object
	Set ouVec1 = App.feOutput
	Dim ouVec2 As Object
	Set ouVec2 = App.feOutput
	Dim ouVec3 As Object
	Set ouVec3 = App.feOutput
	Dim nb_load As Long
	Dim nb_element As Long
	Dim ouSetID As Long
	Dim totalShear As Double
	Dim shear1 As Double
	Dim shear2 As Double
	Dim axial As Double
	Dim UC_shear As Double
	Dim UC_axial As Double
	Dim UC_max_axial As Double
	Dim Max_ID_axial  As Double
	Dim Max_OS_axial  As Double
	Dim	UC_max_shear As Double
	Dim Status As String
	Dim OutText1 As String
	Dim OutText2 As String
	Dim OutText3 As String
	Dim OutText4 As String
	Dim OutText5 As String
	Dim OutText6 As String
	Dim Max_status As String
	UC_max_shear = 0
	UC_max_axial = 0
	UC_max_shear = 0
	UC_max_axial = 0
rc = App.feAppMessage(4, "**** API simple bolt check started ****") 	'Black bold
rc = App.feAppMessage(2, "***************************************")
rc = App.feAppMessage(2, "Simple bolt checks according to AISC (ASD) 9th edition.")
rc = App.feAppMessage(2, "Rev. 0 , Date: 21-02-2017, Created by P. Barabas (barabas.pete [at] gmail.com).")
'Label to navigate with GoTo
Select_element:
Elem_set.Select(FT_ELEM,True,"Select BEAM elements to process")
'supress (remove) any plates selected accidentally
    Dim elt_plate As Object
    Set elt_plate = App.feSet
    elt_plate.AddRule(FET_L_PLATE,FGD_ELEM_BYTYPE)
    Elem_set.RemoveSet(elt_plate.ID)
 'supress (remove) any RIGIDS selected accidentally
    Dim elt_rigid As Object
    Set elt_rigid = App.feSet
    elt_plate.AddRule(FET_L_RIGID,FGD_ELEM_BYTYPE)
    Elem_set.RemoveSet(elt_rigid.ID)
If Elem_set.Count = 0 Then
	GoTo Select_element
	Else
		'do nothing
End If
nb_element=Elem_set.Count
Select_OutputSet:
App.feSelectOutputSets("Select output sets to process", load_set)
If load_set.Count = 0 Then
	GoTo Select_OutputSet
	Else
		'do nothing
End If
nb_load=load_set.Count
' create DropList for User Dialog
Dim BoltList (16) As String
Dim BoltMaterialList (2) As String
Dim OVR_List (2) As String
BoltList (0) = "M4"
BoltList (1) = "M6"
BoltList (2) = "M7"
BoltList (3) = "M8"
BoltList (4) = "M10"
BoltList (5) = "M12"
BoltList (6) = "M14"
BoltList (7) = "M16"
BoltList (8) = "M18"
BoltList (9) = "M20"
BoltList (10) = "M22"
BoltList (11) = "M24"
BoltList (12) = "M27"
BoltList (13) = "M30"
BoltList (14) = "M33"
BoltList (15) = "M36"
BoltList (16) = "M39"
BoltMaterialList (0) = "5.6"
BoltMaterialList (1)= "8.8"
BoltMaterialList (2)= "10.9"
OVR_List (0) = "1.00"
OVR_List (1)= "1.33"
OVR_List (2)= "1.50"
	Begin Dialog UserDialog 390,266 ' %GRID:10,7,1,1
		GroupBox 20,7,350,56,"System of Units",.GroupBox2
		text 40,28,290,21,"FEMAP force input must be in [N].",.Text5
		GroupBox 20,70,350,147,"Select Properties",.GroupBox1
		text 40,91,190,21,"BOLT SIZE",.Text1
		DropListBox 240,91,120,21,BoltList(),.DropListBox1
		text 40,119,190,21,"BOLT GRADE",.Text2
		DropListBox 240,119,120,28,BoltMaterialList(),.DropListBox2
		text 30,147,190,21,"Allowable Overstress Ratio",.Text3
		DropListBox 240,147,120,28,OVR_List(),.DropListBox3
		text 30,182,190,28,"Threads INCLUDED in shear plane?",.Text4
		OptionGroup .Threads_included
			OptionButton 240,175,120,14,"No",.OptionButton4
			OptionButton 240,196,120,14,"Yes",.OptionButton5
		CancelButton 90,224,120,35
		OKButton 230,224,120,35
	End Dialog
	Dim dlg As UserDialog
	Dialog dlg
'capture user input
'rc = App.feAppMessage(2, "Unit system scale factor: " & Scale  )
	'input for bolt size
		Dim BoltSize As Double
		If  dlg.DropListBox1 = 0 Then
			BoltSize = 4
		ElseIf  dlg.DropListBox1 = 1  Then
			BoltSize = 6
		ElseIf  dlg.DropListBox1 = 2  Then
			BoltSize = 7
		ElseIf  dlg.DropListBox1 = 3  Then
			BoltSize = 8
		ElseIf  dlg.DropListBox1 = 4  Then
			BoltSize = 10
		ElseIf  dlg.DropListBox1 = 5  Then
			BoltSize = 12
		ElseIf  dlg.DropListBox1 = 6  Then
			BoltSize = 14
		ElseIf  dlg.DropListBox1 = 7  Then
			BoltSize = 16
		ElseIf  dlg.DropListBox1 = 8  Then
			BoltSize = 18
		ElseIf  dlg.DropListBox1 = 9  Then
			BoltSize = 20
		ElseIf  dlg.DropListBox1 = 10  Then
			BoltSize = 22
		ElseIf  dlg.DropListBox1 = 11  Then
			BoltSize = 24
		ElseIf  dlg.DropListBox1 = 12  Then
			BoltSize = 27
		ElseIf  dlg.DropListBox1 = 13  Then
			BoltSize = 30
		ElseIf  dlg.DropListBox1 = 14  Then
			BoltSize = 33
		ElseIf  dlg.DropListBox1 = 15  Then
			BoltSize = 36
		ElseIf  dlg.DropListBox1 = 16  Then
			BoltSize = 39
		Else
			rc = App.feAppMessage(3, "Bolt size ERROR"  )
		End If
'rc = App.feAppMessage(2, "Selected bolt size: " & BoltSize & " [mm]"  )
	'input for bolt grade
		Dim F_ub As Double
		If  dlg.DropListBox2 = 0 Then
			F_ub = 500
		ElseIf  dlg.DropListBox2 = 1  Then
			F_ub = 800
		ElseIf  dlg.DropListBox2 = 2  Then
			F_ub = 1000
		Else
			rc = App.feAppMessage(3, "Grade selection ERROR"  )
		End If
'rc = App.feAppMessage(2, "Bolt ultimate tensile strength: " & F_ub & " [MPa]"  )
	'input for Allowable Overstress Ratio (OVR)
		Dim OVR As Double
		If  dlg.DropListBox3 = 0 Then
			OVR = 1.00
		ElseIf  dlg.DropListBox3 = 1  Then
			OVR = 1.33
		ElseIf  dlg.DropListBox3 = 2  Then
			OVR = 1.50
		Else
			rc = App.feAppMessage(3, "OVR selection ERROR"  )
		End If
'rc = App.feAppMessage(2, "Allowable Overstress Ratio: " & OVR  )
	'input for Thread in Shear Area
		Dim TSA As Boolean
		If  dlg.Threads_included = 0 Then
			TSA = False
		ElseIf  dlg.Threads_included = 1  Then
			TSA = True
		Else
			rc = App.feAppMessage(3, "Thread selection ERROR"  )
		End If
'rc = App.feAppMessage(2, "Thread included in shear plane: " & TSA  )
' calculate basic constants for AISC (ASD) code check 9th Edition, Table J3.2
	'cross section area of bolt
	Dim A_bolt As Double
	A_bolt =Format( (BoltSize * BoltSize) * 3.1415926535 / 4 , "#.#0")' in [mm^2]
	'Tensile capacity of one bolt
	Dim fb_tensile As Double
	fb_tensile = Format( 0.33 * A_bolt * F_ub, "#.0") ' in [N/mm2]
	'Shear capacity of one bolt
	Dim fb_shear As Double
		If TSA = False Then
			fb_shear =Format( 0.22 * A_bolt * F_ub, "#.0") ' in [N/mm2]
		Else
			fb_shear = Format(0.17 * A_bolt * F_ub, "#.0") ' in [N/mm2]
		End If
rc = App.feAppMessage(2, "Selected bolt size: " & BoltSize & " [mm]; " & "Bolt Area: " & A_bolt & "[mm]; Bolt ultimate tensile strength: " & F_ub & " [MPa]" & " ; Tensile capacity [N]: " & fb_tensile & " ; Shear capacity [N]: " & fb_shear  )
rc = App.feAppMessage(2, "*")
'walk through all the selected output sets and all selected bolts
load_set.Reset
While load_set.Next
		rc = App.feAppMessage(4, "Output Set: " & load_set.CurrentID & "  *******************************************************************")
		'create the header
									  				    '<-------1><-------2><-------3><-------4><-------5><-------6><-------7><-------8><-------9><------10>
			rc = App.feAppMessage(2,"ElemID   | Output Set |Axial Force [N] | Shear Force [N] | Allowable Axial Force [N] | Allowable Shear Force [N] | UC Axial | UC Shear | Status")
			Elem_set.Reset
			ouSetID = load_set.CurrentID
		While Elem_set.Next
					feElem.ID = Elem_set.CurrentID
				'code here to extract the loads
					ouVec1.setID = ouSetID
					ouVec2.setID = ouSetID
					ouVec3.setID = ouSetID
					rc = ouVec1.Get( 3018 ) 'Beam Shear 1
					rc = ouVec2.Get( 3019 ) 'Beam Shear 2
					rc = ouVec3.Get( 3022 ) 'Beam Axial Force
					shear1 =  Format(ouVec1.Value( feElem.ID ),"#.0")
					shear2 =  Format(ouVec2.Value( feElem.ID ),"#.0")
					axial =  Format(ouVec3.Value( feElem.ID ),"#.0")
					'rc = App.feAppMessage(2,"For Element " + Str$(feElem.ID) + " Axial, Total Shear " + Str$( axial ) + " " + Str$( totalShear ) )
				'code to calculate shear force and consider tension only in bolts
					totalShear = Format(Sqr( shear1 * shear1 + shear2 * shear2 ),"#.0")
						If axial<0 Then
							axial = 0
						Else
							'do nothing
						End If
				'code to calculate Unity Checks
						UC_axial = Format( axial / fb_tensile , "#.00")
						UC_shear = Format( totalShear/ fb_shear , "#.00")
						If UC_axial < OVR And UC_shear < OVR Then
							Status="OK"
							Else
								Status="Fail"
						End If
				'add code here to collect the max UC
						If UC_max_axial<= UC_axial Then
							UC_max_axial = UC_axial
								Max_ID_axial = feElem.ID
								Max_OS_axial = load_set.CurrentID
							Else
								'do nothing
						End If
						If UC_max_shear<= UC_shear Then
							UC_max_shear = UC_shear
								Max_ID_shear = feElem.ID
								Max_OS_shear = load_set.CurrentID
							Else
								'do nothing
						End If
				'add code here to write the output to the message window
						'Formatting the output fields
							OutText1 = Left(CStr(Elem_set.CurrentID) & "                    ", 9)
							OutText2 = Left(CStr(load_set.CurrentID) & "                    ", 12)
							OutText3 =Right(CStr( "                                             " & axial) , 16)
							OutText4 = Right(CStr("                                             " &totalShear) , 17)
							OutText5 = Right(CStr("                                             " &fb_tensile) , 27)
							OutText6 = Right(CStr("                                             " &fb_shear) , 27)
					'rc = App.feAppMessage(2,"ElemID   | Output Set |Axial Force [N] | Shear Force [N] | Allowable Axial Force [N] | Allowable Shear Force [N] | UC Axial | UC Shear | Status")
				rc = App.feAppMessage(2,OutText1 & "|" & OutText2 & "|" &  OutText3 & "|" & OutText4 & "|" & OutText5 & "|" & OutText6 & "|   " & UC_axial & "   |   " & UC_shear & "   | " & Status )
		Wend
Wend
'add the code check summary here
rc = App.feAppMessage(4, "****************************** Bolt Checks Summary ***********************************")		'black bold
rc = App.feAppMessage(2, " Max UC axial : " & UC_max_axial & "  at element ID: " & Max_ID_axial & " OutPut Set ID: " & Max_OS_axial)
rc = App.feAppMessage(2, " Max UC shear: " & UC_max_shear & "  at element ID: " & Max_ID_shear & " OutPut Set ID: " & Max_OS_shear)
						If UC_max_axial > OVR Or UC_max_shear > OVR Then
								Max_status = "FAIL"
							Else
								Max_status = "OK"
						End If
rc = App.feAppMessage(4, " Overall Status: " & Max_status )
rc = App.feAppMessage(2, "***************************************************************************") 	' blue text
rc = App.feAppMessage(3, "*** There may be other check necessary, like bearing and tear out!!! ****")		' red bold
rc = App.feAppMessage(4, "****************************** Finished ***********************************")		'black bold
End Sub
 Enjoy!
Solution
Solution
Accepted by topic author PBarabas
‎02-23-2017 01:56 AM
Re: Simple Bolt Check (AISC ASD 9th edition) API for FEMAP , Metric bolts
Hello PBarabas,
I think there is a failure in your code:
    'elt_plate.AddRule(FET_L_RIGID,FGD_ELEM_BYTYPE) -- this must be elt_rigid
    elt_rigid.AddRule(FET_L_RIGID,FGD_ELEM_BYTYPE)
Best regards,
Peter Kaderasz
[ Edited ]
Yes, you are correct. I have updated the code. Thanks for your input!
' Rev. 2 , Date: 25-03-2017, Created by P. Barabas (barabas.pete [ at ] gmail.com)
Sub Main
RESTART:
Call Bolt
If rc = -1 Then
GoTo RESTART
End If
End Sub
Sub Bolt
Dim nb_load As Long
Dim ouSetID As Long
Dim axial As Double
Dim comb As Double
Dim UC_comb As Double
Dim UC_max_comb As Double
Dim Max_ID_comb As Double
Dim Max_OS_comb As Double
Dim OutText7 As String
Dim OutText8 As String
Dim OutText9 As String
Dim OutText10 As String
UC_max_shear = 0
UC_max_axial = 0
UC_max_comb = 0
rc = App.feAppMessage(2, "Rev. 1 , Date: 05-03-2017, Created by P. Barabas (barabas.pete@gmail.com).")
rc = App.feAppMessage(2, "Note 1: The combined bolt check is according to AISC 13th Edition, Formula (J3-3b), all other checks are according to AISC 9th Table J3.2 ")
Select_element:
rc=Elem_set.Select(FT_ELEM,True,"Select BEAM elements to process")
If rc = FE_CANCEL Then Exit Sub
GoTo Select_element
Else
'do nothing
End If
Select_OutputSet:
rc=App.feSelectOutputSets("Select output sets to process", load_set)
If rc = 0 Then Exit Sub
If rc = FE_NOT_EXIST Then Exit Sub
Else
'do nothing
End If
BoltList (0) = "M4"
BoltList (1) = "M6"
BoltList (2) = "M7"
BoltList (3) = "M8"
End Dialog
Dialog dlg
'capture user input
BoltSize = 4
BoltSize = 6
BoltSize = 7
BoltSize = 8
BoltSize = 10
BoltSize = 12
BoltSize = 14
BoltSize = 16
BoltSize = 18
BoltSize = 20
BoltSize = 22
BoltSize = 24
BoltSize = 27
BoltSize = 30
BoltSize = 33
BoltSize = 36
BoltSize = 39
Else
End If
Dim F_ub As Double
F_ub = 500
F_ub = 800
F_ub = 1000
Else
End If
Dim OVR As Double
OVR = 1.00
OVR = 1.33
OVR = 1.50
Else
End If
Dim TSA As Boolean
TSA = False
TSA = True
Else
End If
If TSA = False Then
Else
End If
rc = App.feAppMessage(2, "Selected bolt size: " & BoltSize & " [mm]; " & "Bolt Area: " & A_bolt & " [mm2]; Bolt ultimate tensile strength: " & F_ub & " [MPa]" & " ; Tensile capacity [N]: " & fb_tensile & " ; Shear capacity [N]: " & fb_shear )
load_set.Reset
While load_set.Next
'create the header
rc = App.feAppMessage(2,"ElemID | Output Set |Axial Force [N] | Shear Force [N] | Allowable Axial Force [N] | Allowable Shear Force [N] | UC Axial | UC Shear | UC Combined | Status")
Elem_set.Reset
While Elem_set.Next
If axial<0 Then
axial = 0
Else
'do nothing
End If
' UC combined calculation is from Equation J3-3b of AISC 13th Edition!!!! As similar formula does not exist in AISC 9th Edition.
comb = 1.3 * fb_tensile - (fb_tensile / fb_shear) * totalShear
If fb_tensile < comb Then
UC_comb =Format( axial / fb_tensile , "#.00")
Else
UC_comb =Format( axial / comb , "#.00")
End If
If UC_axial < OVR And UC_shear < OVR And UC_comb < OVR Then
Status="OK"
Else
Status="Fail"
End If
Else
'do nothing
End If
Else
'do nothing
End If
If UC_max_comb<= UC_comb Then
UC_max_comb = UC_comb
Max_ID_comb = feElem.ID
Max_OS_comb = load_set.CurrentID
Else
'do nothing
End If
OutText4 = Right(CStr(" " & totalShear) , 17)
OutText5 = Right(CStr(" " & fb_tensile) , 27)
OutText6 = Right(CStr(" " & fb_shear) , 27)
OutText7 = Right(CStr(" " & UC_axial) , 4)
OutText8 = Right(CStr(" " & UC_shear) , 4)
OutText9 = Right(CStr(" " & UC_comb) , 9)
OutText10 = Right(CStr(" " & Status) , 5)
rc = App.feAppMessage(2,OutText1 & "|" & OutText2 & "|" & OutText3 & "|" & OutText4 & "|" & OutText5 & "|" & OutText6 & "| " & OutText7 & " | " & OutText8 & " | " & OutText9 & " | " & OutText10)
Wend
Wend
rc = App.feAppMessage(2, " Max UC comb: " & UC_max_comb & " at element ID: " & Max_ID_comb & " OutPut Set ID: " & Max_OS_comb)
If UC_max_axial > OVR Or UC_max_shear > OVR Or UC_max_comb > OVR Then
Max_status = "FAIL"
Else
Max_status = "OK"
End If
End Sub
