The principle stress change their direction for an analysis non linear
I have a problem with changing stress direction axes index for a non linear (elasto-plasticity) analysis . My load principle is along axis-Z and after non linear analysis  (NL Static analysis) the corresponding principal stress direction is given as axis-X. Is there  a way to prevent this change of axis for non linear analysis ?
NB : this problem is not found in the case of linear static analysis.
Thank you for your explanation.
