V11.2 to V11.1 Plate Elements Taper
I Noticed that when exporting a neutral file from V11.2 of a model containing some tapered thicknesses defined on some elements with the "new functionality" and importing it back to V11.1 this taper definition is reinitiliased for those elements.
I knew about the new plate elements thicknesses definition for the V11.2 to avoid creating one property for each element when doing it with previous versions...but I would to know if there is a way to keep it as is when importing a neutral into older version.
Seifeddine Naffoussi
