Von Mises Stress Plate Top/Bottom
Dear all,
When I was using Ansys, I had evaluated results according to von mises both combined top/bottom plate stress.
Now I am using FEMAP but there is no option to show max bottom/top plate stress results.
In order to achieve this is there any trick to show max stress.
Re: Von Mises Stress Plate Top/Bottom
Press F5
In Output vector check box " Double Sided Planar Contour"
I am using ver 10. There is no option for double sided.  Smiley Frustrated
Look in the "Contour Options" dialog. You must also choose to do an Elemental contour.
