Weight with just rod,bar, and plates?
I did my homework and couldn't find this anywhere:
I have an imported model consisting of just rods, bars, and plates. A modal analysis gives the correct results.
But I can't get a simple weight or mass total in Femap. The mass measure Solids selection is greyed out. The mass measure Meshed doesn't select anything.
Thanks in advance,
Newbie
Re: Weight with just rod,bar, and plates?
Did you try the command Tools > Mass Properties > Mesh Properties ?
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
You got another beer Chip! I didn't want a list of every element, just the total, so I didn't check "List every element" under the Mesh option. If I check that, I get a total.
