cancel
Wireframe mode via API
I would like to set the mode from Solid to Wireframe via API. I haven't find in manual the function that does that (maybe I missed it):
I'm trying to show all peak spots in my model. To be able to see small spots I need to use Wireframe mode:
Is this possible via API at all? How it can be done?
Yarko
Re: Wireframe mode via API
There is no way to just call Wireframe, however you can accomplish the same thing using the View Object.
The following code shows how to do it.
The HTML Clipboard
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim vuID As Long
    Dim v As femap.View
    Set v = App.feView
    App.feAppGetActiveView( vuID )
    v.Get(vuID)
    v.Mode = FVM_DRAW
    v.Draw(FVI_FILL_ELEM) = False
    v.Draw(FVI_SHADING) = False
    v.Put(vuID)
    v.Regenerate()
End Sub
Hi grudy,
Thanks, works perfect!
I had in mind to use feFileProgramRun function but defenetely your solution is what I was looking for.
Yarko
