api to write solid ID of a group to data table.
anybody knows which api function can list solid ID of an exist group, then write them to data table?
Thanks so much.
TB2006
Re: api to write solid ID of a group to data table.
Siemens Genius Siemens Genius
Siemens Genius
tb2006,
You can use AddEntityData in FEMAP tool objects. I just created a set and added the solids of a selected group into that set. Here's a short script, I'm relatively newer to FEMAP so hopefully this helps.
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim solset As femap.Set
    Set solset = App.feSet
    Dim solgrp As femap.Group
    Set solgrp = App.feGroup
    solgrp.SelectID("Select Group")
    solset.AddGroup(FT_SOLID, solgrp.ID)
    App.feDataTable.Lock(False)
    App.feDataTable.AddEntityData(True, FT_SOLID, 0, solset.ID)
End Sub
Dear T_Giampietro,
This is very helpful to me . Thank you so much.
