bug in contour vector?
A strange thing occurs when using "Contour Vector Options" with 3D components: the last component is systematically reset to the 2nd component (when you return in the window after having left it).
I am not sure what FEMAP displays, i.e; I am not sure that FEMA displays the output wit an error, but at the very least it is confusing when checking.
If I set the output, display, go back to the window (3rd vector has changed), click "ok" and re-display the display changes.
I am using FEMAP v11.0.1, I do not know wether this has already been spotted/adressed.
Re: bug in contour vector?
This problem had already been noticed.  The upcoming (perhaps this week) FEMAP v11.1.1 takes care of it.
Mark.
