deflection/stress not proper in linear static analysis
i am modelling a cylinder with a C section on top of it, on the extreme left end, its clamped(fixed) and i have applied point loads at the cantilever tip(at nodes).. the whole model is made with shell elements...... i am doing a linear static analysis, and when i check the displacements, i see that only the element connected to the loading node gets deflected, the stress/displacement is zero everywhere else, i am sure that there is no fixity other than the one at extreme left end. please guide me.
Re: deflection/stress not proper in linear static analysis
attach your model (if it is not confidential) and we will look at it.
your are working with groups?
did you launch a free free analysis to check your six rigid body modes?
check you are constraining the right nodes and verify the load you've applied...
Seifeddine Naffoussi
