embed solid
hi,
i have 4 parts. after embed solid, in tree i have only one part (solid)
how to get back the remaining solids (parts)?
before embed solidbefore embed solidafter embed solidafter embed solid
Re: embed solid
Siemens Legend Siemens Legend
Siemens Legend
Shreeharsha1,
Could you help illustrate what is happening with some pictures? And what exact commands are you using?
Re: embed solid
@T_Giampietro
HI,
command which i am using is geometry-solid-embed
the output what i am getting is here in pic.
before embedbefore embedafter embedafter embed
please find the attached cad model for your reference.
regards,
shreeharsha
Re: embed solid
Siemens Legend
What exactly are you trying to accomplish?
I believe Geometry > Solid > Embed is used more for the method of when you create/move a solid within/overlapping the volume of  another existing solid. After the command is run the solid volume within the bigger solid will be removed from the bigger.
Simple example:
1. Created solid cube
2. Created cylinder within the volume of the cube
Shown together-
3. After command and hiding the cylinder
Re: embed solid
@T_Giampietro
 i am trying to create fluid mesh..
Re: embed solid
Siemens Legend
To do that you will want to use the command Geometry >  Solid > Fill Hole. Select an inner curve on the solid "case".
Now there is another solid within the "case" solid. Note the geometry list in Model Info
Now you will want to use the command Geometry > Solid > Embed. Select the newly created solid. Then select one of the inner three solids (2. pcb 3. chip 4. chip2 ). Repeat twice for the other two inner solids.
This will leave all solids.
Re: embed solid
@T_Giampietro
thank you. got it.
but one more question i have?
if i project a circle on the front face of the embed body (case), i cant able to apply tetra mesh to that. it is prompting like only single surface boundaray required?
then how to combine the project circle face with embed body?
regards,
shreeharsha
