export displacment for nodes???
Hi, I try to export nodes after i defined them as group. I build a group of these nodes as picture below, and run analysis after choosing only this group to post out. My equation how could i see these nodes displacement after analysis??? and if i want to apply this displacement to only small rectangle alone without the big rectangle, is there a way for that???
Re: export displacment for nodes???
Dear Bashar,
You can use the macro to update your mesh with displacement results from your analysis, you have two very intesresting APIs under CUSTOM TOOLS > POSTPROCESSING, feel free to try them and enjoy!:
Best regards,
Blas.
WEB: http://www.iberisa.com
Thank you Blas_Molero for your answer. I dont know why it didnt work for me and when I click ion ''Nodes move by deform with options '' It gives me the first picture as attach then dispared.
I used another way by using data table thereefter list ---- output----results to data tables--
by this way could choose the deofrmation or rotation for some nodes then export as 'csv' . Therefter i import it as a result import----analysis result ---- comma seperated
It is work and thereefter model ----load ----from output
This, it works but it seems that the program dosent defined the displacment as a force in nodes or kind of effect. I run the simulation but it gives me fatal 4551.0 which means
4551.0 *** USER FATAL MESSAGE 4551 (NL2CON)
STOPPED PROBLEM DUE TO FIVE CONSECUTIVE DIVERGING TIME
STEPS.
User information:
A solution is not possible. Review NLPARM requests and modify
to select a better solution approach.
I am export the nodes and apply it for the small rectangle. I dont know if you have an idea about that?? Thanks
