feWindowGETsize? (API)
I know i can set the window size of my current window using
 App.feWindowSetSize(0, Left, top, width, height)
but how can I get the size of the current window? According to the api.pdf there is no such thing as feWindowGetSize
Maarten
Maarten Elings | Mechanical Engineer
Re: feWindowGETsize? (API)
If you can find the handle to the view window, then you should be able to use the windows API GetWindowRect function to get the window size.  I'm sure sure if there is a simple way to get the view window handle though.
