install failed
N/A
Hello Siemens Team,
I've downloaded the trial (784,737kb '.exe') but on launching the file I receive the 'meaningless' message seen in the attachment. Any idea what it means?
Thanks in advance,
Hugh Price
Antonov Automotive Technologies. +44(0) 1926 455 801
Re: install failed
Innovator
Innovator
Dear Hugh,
I note in your image that the size of download is very small, the real size is about 1 GB, then this means that the downloading process was not performed correctly, repeat again, but make sure to use any donwload app (FDM, JDownloader, etc..) , not using directly the browser, this is critical in downloads bigger than 1 GB.
Best regards,
Blas.
Re: install failed
N/A
Hi Blas, Thanks very much. I believe I've solved the problem now, probably by repeating the download.
All the best, Hugh
