loading a library from API does not work
Hi
i am trying to access a property library by the following code:
Sub getlib()
Dim app As Object
Set app = GetObject(, "femap.model")
Dim prop As Object
Set prop = app.feProp
prop.GetLibrary (1)
MsgBox (prop.title)
End Sub
though i have content in my library, it does not work the first time. suppose i edit once in FEMAP, then this works fine.
why?
could someone pls help me with is.
Re: loading a library from API does not work
You must first set the active element type using
App.Info_ActiveType (FT_ELEM) = "Type of Element/Property to Get from Library" or use the GetLibraryOfType method from the property object.  See the remarks of sections 5.1.2.2 and 5.49.3.10 of the API Reference.
Sub getlib()
    Dim app As Object
    Dim prop As Object
    app.Info_ActiveType(8) = 6
    prop.GetLibrary (1)
    MsgBox (prop.Title)
End Sub
Sub getlib()
    Dim app As Object
    Dim prop As Object
    prop.GetLibraryOfType 1, 6
    MsgBox (prop.Title)
End Sub
Thank you so much, and got your point.
The "app.Info_ActiveType" worked but "getlibraryoftype" did not work.
It said Object doesnt support this property of method. I also searched in my help but i could not find.
Is it due to version, i use 10.3.1?
