reverse curves already meshed
Hi at all, Someone know a quick method to reverse a beam (and his diagram of bending) without necessarily go from modify-update other-reverse curve and re-mesh?
FB
Re: reverse curves already meshed
Use the Modify -> Update > Line Elements - Reverse Direction command.
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
...but I don't think the beam diagram reverses though.  I think you'll need to run the analysis again to get the results to match (End A vs End B)
yes, I need to rerun analysis Smiley Wink
