revolved quad mesh not touching surface
I revolved a quad mesh into a solid and have it all associated to the solid except for the white surface below.  How can I fix this?
Re: revolved quad mesh not touching surface
If you used the command, Modify > Associativity > Automatic command, you may need to loosen the value of the Search Tolerance in the Automatic Geometry Associativity dialog box.
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
