solution 601/106
Builder
Builder
Me again.
How can I model a material that behaves differently under compression stress (compared with tensile stress)?
Many thanks
Ionut
Re: solution 601/106
In your material function "stress vs. strain" input the tensile and compressive behaviour of the material.
Saptarshi
Builder
Builder
That is, negative values for strain and stress?
Yes. Something similar to this should work:
