stress linearization
I found  https://community.plm.automation.siemens.com/t5/Femap-Knowledge-Base/FEMAP-Stress-Linearization-Tool... about stress linearization.
The macro seems to work but then the user is asked linear plate or  linear solid. It does not work for tetra10 parabolic tetra. Anyway I tried it I got an error. I guess not
Re: stress linearization
Dear Jon,
The FEMAP Stress Linearization Tool run OK with parabolic CTETRA 10-nodes elements, here you are:
Please explain the error you have.
Best regards,
Blas.
WEB: http://www.iberisa.com
Hello Blas,
It is the same error as posted in by AMinati
http://community.plm.automation.siemens.com/t5/Femap-Discussion-Forum/FEMAP-Stress-Linearization-Too...
I found this post later but no solution is given
FEMAP version 11_2
I have the same error message as well. Basically an unhandled MS .NET Framework error. It is a software bug -- probably something not complying with Microsoft requirements. This is with Femap 11.2.2. I downloaded and installed the FSLT_112 version but it does not work either. It craps out as soon as you finish selecting the nodes. Also craps out if you select any other control option.
Hello!,
Please install this program, it works for me OK in FEMAP V11.2.2
Best regards,
Blas.
Hi Blas,
Thanks.  That one works.
Cheers,
Chris
Hi Blas,
I got an error "Could not interpolate a stress value at location 450.6901, 2.882334, 481.2793"
I couldn't solve this error, My FEMAP ver. 11.1.2, and I tried every versions of stress linerization tool which are in this knowledge bases post. Could you give me any recommandation.
Cheers,
Seung
If you send me your FEMAP model, and tell me which two nodes you are picking for stress linearization, I will debug it -
sherman dot mark at siemens dot com
Mark.
